Xfiver's avatar
Xfiver
Loud Splendide dryer
We used the washer and dryer for the first time in our Journey and the washer works great but the dryer is very loud. Sounds like a loud motor or a bad bearing, anyone else experience this with a Splendide TVM63X. Our Journey is a 2013 and we just purchased it used and we have had no previous experience with a washer or dryer in a RV.
  • What EVERYONE should do when purchasing a used DP with Splendide washer drayer is to pull it and inspect for lint AND replace the hoses.
    I found a ton of dried lint in the hose and just as much in a rubber boot between the drum and the rear of the washer.
    I first put it in dry mode & noticed almost no air exiting the outside vent.
  • We have the 2100 vented and only have noise and or vibration when rinse/extraction as sometimes the load is unbalanced. While on dryer mode a slight hum, good to go to sleep by.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
