bcbob's avatar
bcbob
Low amps from solar panels
I have 2 Renogy 100 watt solar panels flat mounted on my motor home.
19.9 volts from panels to charge controller with a 30 amp inline fuse between panels and CC. Charge controller is a 30 amp PWM. My question is.....the panels can produce up to 5.62 amps each, but are now only producing between 2-4 amps in mid day full sun. Any suggestions on what can be done short of getting on the roof? The volts coming from the panels seem OK, but the amps are way low. Up until a few days ago I was getting between 9-10 amps. Panels are in parallel.
When I remove the inline fuse my amp meter will read the same as the CC.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 23, 2026
