I have a 2006 Bounder with a CAT 300 (C7)turbo desiel engine. I have had the RV sitting in RV spot for about a year and am ready to move on in about a month. I start up and run the engine (and g...
The Check Engine Lite - will only derate the engine, not shut it down unless you hit the 226 degrees temperature, low oil pressure in the HEUI. And by the way, did you check the coolant level in the radiator/recovery tank first? Because your post stated "Fluid Low".
By the way ECC = Engine control code
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
