Hemlockdj's avatar
Hemlockdj
Low-No propane flow question
Good day all,
So I have camped many times in winter in truck campers & trailers and never seen this issue.
Battery full charge(new)- Check
Propane tank full/on - Check
Heater No obstruction on vents/sail switch - Check
Hot water heater empty from winterization - Check
Went to load/prep our Class C 23C Chateau motorhome for a trip to San Diego last week. Nighttime temperatures here in Colorado low 20's, daytime 40-60. Friday afternoon, about 50 degrees, Turned on the Stovetop, gas flowing, good flame. Turn on frig on Propane, pilot light all good. Turned on heater, NO light!
Checked everything, seems fine.
Next Day, Saturday, went out to troubleshoot some more, outside temps about 35 degrees, stovetop NO flame, frig pilot working fine, heater still not lighting.
Drove south towards Santa Fe, NM on Saturday, outside temps around 60 degrees. Stop for the night, stove top, frig & heater all working fine on propane. Everything worked fine for the remainder of the trip.
For some reason propane was not getting to the heater & stovetop when it was cold outside. Never seen this. The heater and the frig are on the same side of coach and stovetop on the opposite side.
Any ideas?
Thanks in advance,
Dave
  • One thing I forgot to add, sorry, the heater would light for about 1-2 seconds than go out.
    Hemlockdj wrote:
    Good day all,
    Any ideas?
    Thanks in advance,
    Dave
  • maybe the tank was overfilled? That happened to us once. The liquid was freezing inside the regulator. We poured hot water on the regulator and were able to get the furnace to come on. After we used enough propane to bring it back to the appropriate level, everything worked fine again.
Having RV issues? Connect with others who have been in your shoes.24,235 PostsLatest Activity: Apr 18, 2025
