Davidlee64's avatar
Davidlee64
Low propane indicator?
I have 2 propane tanks with an auto switching regulator. The regulator does exactly what it is designed to do. The only bad part is I don't know when it switches unless I go outside and check it daily. That could be risky when it's cold outside as I wouldn't know how long it had been on the backup tank. The other day I switched it over, didn't have a spare tank, and ran out before I could get tanks filled. What I need is some sort of gauge or indicator that I can wire up to something inside the RV that I can glance at. The only other option at the moment is to leave #2 tank turned off until needed. Then replace empty, and have at standby. The bad thing would be the furnace quitting from lack of propane at 3 am and 35 degrees outside. Anyone have any suggestions?
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
