BFL13
Mar 24, 2022Explorer II
Agree just use some. You can release some if nervous.
Fill up today. New thing after half hour drive
got out and could smell propane. Fridge was beeping said No Fuel.
Reset fridge to LP went to yellow dot normal drove more next stop smell propane again outside
Checked tank opened closed big valve then found little valve above that was not all the way to the right. Turned it left and it hissed says it is the 80% thing. Hand turned it tight to the right seems to have fixed that.
He had a short rod tool for that as usual not sure what went wrong this time. Hope hand tight is ok.
