cmeade
Oct 09, 2016Explorer
If you are determined to have it your way then install a T fitting with cap and shutoff valve at genny to supply line. Regulator would be attached at portable tank because your 30# tank is unregulated. You would then have a propane hose from 30# tank and regulator to T fitting to genny with shutoff switch "off". Cap the T fitting and turn shutoff valve "on" and frame tank now supplying.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
