GASMAN6674 wrote:
ChooChoo man is correct unless the manufacturer of you grill offers a low press conversion kit it will not work. Some have removed the disposable bottle regulator/hook up an ran low pressure into there grills and it works for them. But most of the time if you remove the regulator/hook up you lose your control valve. Your grill needs to be similar to a full size one but smaller of course.
I have my eye on a stainless steel master forge at Lowes just waiting on clearance.
The hose above connects to where a 1lb bottle will connect to, and the other end will connect to the TEE.
