23hotrodr wrote:
DrewE wrote:
I think a better solution would be to replace the
connector on the motorhome (and of course also on the hose that connects to the 20lb cylinder) with a propane quick connect fitting.
You are probably correct.
Be careful, there are both high pressure and low pressure propane quick connects. Makre sure the propane quick connect is rated for high pressure along with the hose. A lot of the quick connects and hoses for trailers are used after the regulator for outside low pressure accessories. The quick connects are different so you don't blow up low pressure hoses plugging them into high pressure lines.
HP vs LP quick connectors
