Chris_Bryant
Jul 18, 2019Explorer II
It’s just like a fuel,gauge- something like a 90 ohm variable resistor, so there is either a short in the wire, an open in the wire or the element is bad. You can test the wire by disconnecting at the tank gauge and shorting it to ground, something should change if the wire is good.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
