Oasisbob's avatar
Oasisbob
LP PRESSURE ?
Recently noticed the high output burner on my stove is a tad loud and there is a section of openings that do not light on the burner. This moves if I gently blow on them. Also oven pilot has phases where it kinda burps. I replaced my LP pressure regulator five years ago. Could this be a pressure problem? How would I check the regulated pressure? What should it be?
  • Sounds more like air in the line.
    You need to make a manometer. Basically it's a clear tube at least 30 inches long that you fill part way with water. Make the tube into a loop, remove a burner and slip one end over the spud. Turn on the gas, the water level should move about 11 inches up the tube.
    Making a manometer
  • When was last time you CLEANED burners....toothpick openings to clear them and clean out burner gas tube
    RV LP Pressure is 11" WC (that is roughly 0.4 psi)
    A Manometer is used to measure pressure.....connected to gas appliance and then at least 50% of propane appliances in service
    How is Water Heater Flame?
    The Furnace?
    Fridge?
    OTHER stove top burners?
    Could be dirty stove top burner, could be range/oven regulator or could be LP Reg (IF other appliances have issues)
Having RV issues? Connect with others who have been in your shoes.24,350 PostsLatest Activity: Jan 18, 2026
