westend
Apr 09, 2016Explorer
Yes, you'll have to make sure you have 12V in the 12V system. This is best done with a hand held meter. If your interior lights are bright, there is a good chance that you have a working 12V system.
The water heater will be the least problematic to start. There may be a switch inside to turn the water heater circuit board on. There may be a light with that switch to indicate that power is present at the switch. Make sure there is water inside the heater before trying to light.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
