CT_WANDERER
Apr 10, 2016Explorer
Right now I would say it sounds like you are not getting 12 Power to your system. check for fuses or a disconnect switch. Your High low switch and Auto is for your AC System. Which does use 12Volt. So you have to start checking fuses and switches on your heatind systems. When you move your T-Stat to furnace it should start the furnace blower. Then in a few seconds it should fire off. If it does not start the blower you have to check around your furnace for a fuse or switch that may be turned off. See if you have 12 At these point for a starter. I hope I am getting you in the right direction.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
