Undercover_Poe
Apr 10, 2016Explorer
Ok here us what I just tried. I put the battery on charge while hooked up to the camper to simulate a good charged battery. The water pump does run but the overhead fan will not run. I need to be plugged into shore for the fan to run. I was able to cycle the temperature "dial" up and down while on furnace and I heard clicking from the over head fan but nothing running. I do have a multimeter however I don't know what to test other than the battery. After that quick charge she read 13.5 volts so I think the battery is good. I pulled all the fuses and looked for the lights next to them illuminate. Nothing except for one, the bottom 25 amp fuse, when pulled the light next to the fuse above it turned on. I think while pulling the fuses in and out I may have heard that overhead click again. Pictures of my overhead fan assembly.
Fuse pulled and the only light I could get illuminated. Sorry for the bad pic
The one above is better. Here is the fuse put back in and the light turns off
The pic I tried to post above showing the only light I could get on
I'm stumped.
I'm stumped.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
