Undercover_Poe
Apr 11, 2016Explorer
Old-Biscuit wrote:
You don't have a 25A Fuse
Bottom two WERE 7.5A fuses in very first picture posted (and only Five 15A Fuses)
NOW you have SIX 15A and only One 7.5A
You are not getting DC to your Fuses
You are not getting DC thru your Fuses
YOU have DC System Issues
Remove the panel cover (2 screws) and check the DC on Converter terminals were battery cables connect and were DC cable feeds DC Dist Fuse Panel
YOU are not getting DC out of the DC Dist Panel
And it being a WFCO Power Dist..........probably time to get rid of it and replace with a Progressive Dynamics Model
Oh yeah, I mean bottom 7.5 amps. Looks like 25 amp in the pic. I see what you are saying, once the fuses are pulled all the lights should illuminate, so there is a problem with getting DC voltage to the equipment which isn't working. I'll work on investigating where my voltages stops. Maybe my problems are with the panel?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
