joshuajim wrote:
OK, I got my thinking backwards. The spring is augmented by air pressure on the diaphragm as indicated on the attached pic. This would result in decrease in output pressure as you gain altitude, which would be a good thing.
Regulator
Yes there are vents (2 of them) on a 2-stage regulator.
One small on high pressure side and one large on low pressure side.
They do allow for air movement in/out as diaphragm moves.
Spring tension is spring tension regardless of atmospheric pressure.
Spring tension is pre-set based on desired out put.
The vents provide a means for exhausting gas if internal relief valves open OR as 'leak' detector should diaphragms crack
