hpdrver's avatar
hpdrver
LP Regulator
I am replacing the Propane regulator on the motor home and have one question.
The new regulator has in and out ports that seem easy to install but the regulator also has a plastic plug above the vent. What is this plastic part ?
  • Just for other interested thread followers, some of the newer 2 stage regulators are coming through with a 1/8" pipe thread plug in the upper area of the second stage area. This is so a fitting can be installed temporarily to check or adjust the actual output of the regulator. We had a regulator fail about 3 weeks ago and the new one was so equipped. When I checked the old one it was only putting out about 7" WC of pressure instead of 11" WC. And yes, I do have a gauge.
  • It is a Marshall horizontal 2 stage regulator. Cover for adjustment screw makes sense. Thanks
  • You should be installing a horizontal two stage regulator and the vent should be facing down.
    Plastic cap in most cover the adjustment screw. It should be preset, so don't play with it!
  • Picture or part number will allow better answers.
    Could be just a cover over the adjustment screw for calibrating pressure.
    And, is your regulator installed VERTICALLY or HORIZONTALLY. Different PN's for each!
    Also, why are you replacing a 2017 regulator-- what failed?
  • Not sure what regulator you have. Two stage or one? How big is the plug?
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
