desertmoose's avatar
desertmoose
Lube a fresh water drain valve?
We just picked up an older trailer. It's a 97 model. While going thru it, I disinfected the water system with the added bleach approach.
Last night, I went to drain the fresh water tank. The drain valve is accessed by removing the dinette seat board. The valve is attached directly to the bottom of the tank with a hose extending thru the floor. The valve is a molded white plastic with a L shaped turn handle.
Trying to turn the valve, I was sure I was about to break the handle off. It's real hard to turn. I only got it to turn about 90* before I stopped in fear of busting the handle right off. The water is just barely dripping from the discharge hose.
So, it will drain eventually, but I want it to work right. Short of lifting the tank and putting a new valve in, is there any fresh water safe lube I could apply that will get into the valve, free it up, and not degrade the plastic?
I considered a spray silicone, but if it gets into the valve, but would it probably get into the water tank also?
Thanks, Sam
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
