bandit86's avatar
bandit86
Lubing leaf spring pivot points
Just changed all the plastic bushings out today on both axles. Lubed them up with antiseize in and out. Going to stick to my trust mixture of gear oil and grease to lube them on a regular basis. It goes in oily and dries to greasy.
Anybody else oil their spring pins?
  • bandit86 wrote:
    A wise man once said; any grease is better than nothing... I'm sort of going on that.
    Fonzie talking about his hair
  • A wise man once said; any grease is better than nothing... I'm sort of going on that.
  • Betcha nickel they'Re nylon not plastic. Unlubed steel to nylon will wear faster. Never-seize is not really made to be a lube. But what the heck... dry graphite is the material of choice as it embeds into the nylon.
  • Just changed my bushings out to the never-lube going to see how they do.
