Almot's avatar
Almot
Explorer III
Mar 11, 2015
Lugs on #4 battery wire?
Need some education again - or maybe toss a coin. Running 10ft cable from 30A solar controller to breaker box and then to battery. The last 5ft from breaker box to battery is #4 wire with lug at one end. Now, WHICH LUG?
If you look at the top 2 lines in Genuinedealz - they have tinned copper lugs and "heavy wall lugs" (the latter are also tinned copper, as I understand, but with thicker walls).
All their products are good, I know this from previous purchases, but with these 2 kinds of lugs I feel like that donkey between two bales of hay, can't decide which one.
If this helps - environment is mostly dry but close to the sea all the time. Batteries are AGM and located "almost" inside, in trailer basement.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 29, 2026
