Almot
Mar 11, 2015Explorer III
Lugs on #4 battery wire?
Need some education again - or maybe toss a coin. Running 10ft cable from 30A solar controller to breaker box and then to battery. The last 5ft from breaker box to battery is #4 wire with lug at one end. Now, WHICH LUG?
If you look at the top 2 lines in Genuinedealz - they have tinned copper lugs and "heavy wall lugs" (the latter are also tinned copper, as I understand, but with thicker walls).
All their products are good, I know this from previous purchases, but with these 2 kinds of lugs I feel like that donkey between two bales of hay, can't decide which one.
If this helps - environment is mostly dry but close to the sea all the time. Batteries are AGM and located "almost" inside, in trailer basement.
