toedtoes wrote:
I agree each has its limitations and positives. When I made my decision, it really helped to understand why others chose one over the other. It made figuring out which was best for my situation much easier.
Either way, I will never go back to a stinky slinky.
Unfortunately at dump station stinky is the only valid option.
This forum members always hesitate to grab piece of paper and pencil to make quick comparison.
so main points
macerator needs ton of 12V power, SS needs few gallons of water.
Unless you have bypass, macerator will snail gray water, while SS will drain gray water without turning on the jet.
Macerator cost about $300 and has wearable parts.
SS cost $100 (you can build your own with $30 head) and has no wearables.
Macerator has higher lift, so if you need to go over a foot high, you have no SS option.
