w4yn's avatar
w4yn
Mach 15 Questions on Condenser Fan
How do I tell if condenser fan in on shaft correctly?
Also how far into the shroud fan be?
Tim
  • Old-Biscuit wrote:
    Condenser fan blade should split the shroud opening...half in/half out
    Screw that tightens blade onto shaft is towards motor
    Thank you that is what I needed, fan came with blade outside of shroud. Now all is good, for now!
    Tim
  • Condenser fan blade should split the shroud opening...half in/half out
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
