ktmrfs
Oct 10, 2015Explorer III
all it takes in the orfice is a piece of spider web. I've had the oven and fridge orfice look completely clear, but still restrictive until I blew compressed air through the orfice, then everything worked fine. gas pressure is only 0.5 (yes 1/2psi). it doesn't take much to restrict flow with that low of pressure.
BTW if the stove burners work fine, then you have adequate pressure from the regulator.
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 30, 2026
