opnspaces
Jul 22, 2022Navigator III
I read everybody's posts and it just seems to me that you possibly have an obstruction in your orifice or in the burner itself. I would pull the burner and then see if the orifice on the feed tube can be unscrewed with a tiny wrench. If so pull it out and see if you can see sunlight through the tiny hole in the middle. If you have compressed air try to blow the orifice out.
If the stove orifice's are removable then try swapping the burner and the burners matching orifice from a working position and put them in the failed burner position.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
