philh
May 21, 2019Explorer III
pianotuna wrote:
Hi philh,
Batteries don't "boil" unless the temperature inside them is 337 C (~638 f). They do gas.
The device you suggest may cause both positive and negative plate shedding. Basically it "knocks" the hard sulfate off the plates. That buys some time--but the total capacity (amp hours) drops and once the space beneath the plates fills up the battery has had the biscuit.
Here is an example of one such device. I really DO NOT recommend it.
https://www.instructables.com/id/Simplest-Chargerdesulfator-Ever/
That's what I built. It definitely bought time, battery appears to be as good as new. Wonder how many uses before the battery is unusable :)
Gave it to a friend that has a very expensive custom battery... something like $250 for his classic cougar. He wants to keep using the replica battery as long as possible. It worked for him too.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
