SoundGuy
Mar 10, 2017Explorer
pianotuna wrote:
1000 watts is too big, and too small. Too big when running the electric blanket and too small when running the hair drier.
IMO a 1000 watt PSW is "just right" ;) ... sufficiently large to serve as a universal power source to run a small coffee maker, toaster, wife's hair dryer on low or medium, fans, etc, etc. A 1K would typically draw no more than ~ 80 amp max, in which case moderately sized 4 gauge cable can be used to wire it to a pair of GC-2 or G31 batteries, which in turn would offer sufficient reserve to effectively power the inverter. Whether using solar or a genset 2 batts of this capacity will be quicker to recharge than a much larger bank of 4 or even 6. Go with a larger inverter and the ball game changes entirely - much larger battery reserve required, much heavier cable needed for wiring it in, more recharge capability needed. For some it may be worth the investment but for me a 1000 watt is "just right". :)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
