SoundGuy
Mar 10, 2017Explorer
j.p.f. wrote:
I don't understand why a 1500 watt inverter is to big? if you have a 1.5 kw inverter you don't HAVE to use 1.5kw it will still work on a 1kw load.
What's so difficult to understand? There's no sense installing a 1500 watt or larger inverter if it's not wired to properly handle a full load and that in turn requires significantly heavier gauge cable than does a smaller 1000 watt inverter. A bank of fully charged GC-2s will run a 1000 watt but any more than that and you're going to need a heavier battery reserve. So let's say you go ahead and spend the $$$$ to do all the aforementioned but then after the fact never come close to ever using that 1500 watt inverter to it's full capacity. Kinda pointless ... no? :)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
