SoundGuy
Mar 11, 2017Explorer
SoundGuy wrote:
IMO a 1000 watt PSW is "just right" ;) ... sufficiently large to serve as a universal power source to run a small coffee maker, toaster, wife's hair dryer on low or medium, fans, etc, etc. A 1K would typically draw no more than ~ 80 amp max
Almot wrote:
What if DW tries running 180 Amp because accidentally left the switch on hair drier in High?
I guess I give my DW more credit as this has never been an issue ... no different than when running on limited shore power and asking her to dial back the A/C thermostat so just the fan itself is running when she wants to also use the microwave oven. I've only had to explain the reasons why just once, since then that's what she does. JMO, but you're making a mountain out of a molehill. ;)
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
