SoundGuy
Mar 11, 2017Explorer
BFL13 wrote:
However I don't need PSW for anything we use. No electric blanket. If I did, I would get the lowest cost one of the needed watts I could find and use the big MSW for everything else. I note that the recommended ones have no fan noise, so since it is for that blanket and when trying to sleep, that would be a big factor in choosing the inverter
And here in Canada where you and I both are by far the most cost effective deal for a PSW inverter is the 1000 watt Motomaster branded version that many of us have and is in fact cheaper than anything smaller I could find here. In typical Canadian Tire fashion it's on sale regularly for ~ $200 Cdn so while it's no doubt far from the "best" I've not had any issues with mine, it does what it's supposed to do, under lighter loads the fan never runs and when it does it's irrelevant anyway with the inverter mounted in the trailer's front pass through cargo compartment. :B
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
