GordonThree's avatar
GordonThree
Magnum inverter, Yamaha Generator
For anyone that is curious...
A recent thread came up about about abnormal charging from a Magnum inverter, using a Yamaha generator as the AC input. My Magnum is a Magnasine MS2812, software version 5.4, ARC version 3.010, BMK version 1.0
When I started my Yamaha ef2000is this morning, output voltage 122.3 volts.
AGM (automotive grade) battery bank was at 12.3v, 70 pct SOC. The Magnum is charging in bulk mode 14.4 volts and 88 amps (ac input limit set to 13 amps).
A few hours later, output voltage 122.3 volts. Magnum charging in absorb mode, 14.3 volts, 60 amps (ac input limit still 13 amps). SOC 93 pct
It should switch to float shortly, I think around 95 pct?
SOC is being measured by coulomb counting performed by a Magnum battery management controller (BMK)
edit: oh, I should add, minimal ac load is present on the inverter. Just a television, a few chargers, various parasite loads.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
