pianotuna
Apr 03, 2018Nomad III
Hi John,
My 3012 does not exhibit this behavior. It will go to bulk and/or absorb. For example when I've been using load support to run the microwave and the induction cooker at the same time while connected to 15 amp shore power.
I've never seen it go to "standby" mode.
full_mosey wrote:
My biggest problem is that the ABS stage is only available when first powered up. After that, it is stuck in Float at 13.6. Worse yet, after the 4hrs Float it goes into standby mode. In standby, it waits for the Volts to drop below 12.9V and then it repeats Float again.
This is irksome because sometimes I need the 50A for bulk/abs charging but the solar has already raised the Volts above 12.9V. At this point, even if I restart the MMS, it goes straight to Float. I can't force 14.4V! If I need the 50A I must start the MMS early AM or late PM when I can catch the bank below 12.9V.
John
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
