SlownsyExplorerOct 21, 2017Magnum MSH 3012Our inverter bought and installed in our FW in USA and since bought back to Australia was not passing power trough or charging batteries when supplied 110V with a step down transformer, I contacted M...Show More
CA_TravelerExplorer IIIOct 22, 2017BTW If your fiver is 50A did you connect both hot leads to the step down transformer? Did you measure the rig AC voltage under loads in Australia?Have you tried connecting the Magnum to the step down w/o any rig wiring?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 24, 2026
Related ContentCable and fuses for Magnum MSH 3012 M inverterWill Honda 2000 supply MSH 3012's charger?maximum dc voltage output Magnum 3012 with remoteMagnum ChassisMagnum Hybrid Inverters
