Our inverter bought and installed in our FW in USA and since bought back to Australia was not passing power trough or charging batteries when supplied 110V with a step down transformer, I contacted M...
I would not run the air or micro on 50 Hz. Water heat and fridge should be fine but those should be good on propane. Most charging bricks for small items are universal, read the label.
I would be far more inclined to just get a local battery charger and put it direct on the battery. Use the inverter for 120v items as needed.
