Our inverter bought and installed in our FW in USA and since bought back to Australia was not passing power trough or charging batteries when supplied 110V with a step down transformer, I contacted M...
However if you install a bypass switch or transfer switch so there is no shore power being applied/connected to the output side of the inverter you will be ok
You do not want, should not have, live shore power connected to the out put side of the inverter, it will back feedinto components, that should be getting that voltage
