time2roll
Mar 23, 2019Nomad
I have the HF 66150 and I believe it would work u-bolted to a bench. Need to stick out a bit or the thumb wheel to release the hydraulic might be hard to operate. Shank is stepped so you may need a cradle or spacer so it attaches flat.
https://www.harborfreight.com/hydraulic-wire-crimping-tool-66150.html
The head itself does not move. Just the piston inside the handle side.
