brulaz's avatar
brulaz
1/0 lugs with hydraulic crimper
Using the #70 hex dies in my new hydraulic crimper with 1/0 tinned copper lugs (not cast) and 1/0 cable.
I squirt a little anti-oxidant around the lug hole, insert the cable and do a simple crimp. That leaves two small tags sticking out on each side where the upper and lower dies meet. The crimp seems mechanically very strong. Are these tags just a cosmetic issue?
Tried rotating the lug after only half-way crimping, then finishing the crimp. But that seemed to re-stretch and shear the copper lug, making an even messier (and perhaps weaker?) crimp.
Thoughts/suggestions?
