MrWizard
Mar 23, 2019Moderator
i have HF model
the problem is the change in diameter between the handle and the hydraulic pump section, and the valve being on the side of the pump
i think you would need a contoured support for the bench side
to be able to bolt it down, a carved block of wood ? to a allow even support and access to valve so it is not pinched down against the work bench
