pnichols
Oct 17, 2015Explorer II
David: Aren't flooded batteries "fully charged" whenever they will only accept a very low current level (as read from an ammeter) while a temperature compensated 14.X volts is sitting on their terminals? :h
(You can define what good-enough "low current" to look for with respect to the AH capacity of any particular flooded battery bank being charged.)
I'm not sure that either a SG bulb, or equation, is needed if one can merely read an ammeter while applying the correct voltage verus temperature long enough.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
