OutofTime's avatar
OutofTime
Explorer III
Nov 14, 2024
Manually inflating rear airbag on a 1995 Gulfstream Sunsport
I can't get the electronic controls up front to work, so I'm trying to figure out if there is a manual way to get the fill valves to open on the airbags so I can raise up the rear for towing.  I've located the box that contains what is most likely a solenoid for each back and it has a lever sticking out of it.  However, I can't budge the lever by hand.  Does anyone have any documentation on how you can do this process manually, if at all?
No RepliesBe the first to reply
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
