bikendan
Nov 10, 2018Explorer
swimmer_spe wrote:azrving wrote:swimmer_spe wrote:azrving wrote:
What voltages are you seeing as you use it? Have you checked the gravity?
I had it tested and it is good. But I kept killing it. Tells it is still a good battery, but not up for what I need it for.
Maybe you need more than one. Even a true deep cycle may not help you if you try to pull too many amp hours. I run six GC2 and use all they have. Do an energy audit.
Hoow do I do one? Only thing besides the lights is the furnace.
Suggest you Google "the 12 Volt Side of Life". Your battery is used for more than just lights.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
