swimmer_spe
Nov 11, 2018Explorer
bikendan wrote:swimmer_spe wrote:bikendan wrote:swimmer_spe wrote:azrving wrote:swimmer_spe wrote:azrving wrote:
What voltages are you seeing as you use it? Have you checked the gravity?
I had it tested and it is good. But I kept killing it. Tells it is still a good battery, but not up for what I need it for.
Maybe you need more than one. Even a true deep cycle may not help you if you try to pull too many amp hours. I run six GC2 and use all they have. Do an energy audit.
Hoow do I do one? Only thing besides the lights is the furnace.
Suggest you Google "the 12 Volt Side of Life". Your battery is used for more than just lights.
Besides the CO/smoke detector there is nothing else, unless you count the odd time I turn the pump on.
I have no other powered things. I don't have things that have residual power consumption.
The radio clock uses power and some Dometic fridges have a Climate Control feature that drains battery power when not plugged into shore power.
None of those on my trailer.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
