- MrWizardModeratorharbor freight has a low price 'nut sert' tool
they are designed for use in sheet metal
http://www.harborfreight.com/45-piece-threaded-insert-riveter-kit-1210.html
plastic drywall inserts don't work very well unless the hole is in wood, where they can expand and lock in place
if anchoring in stripped out wood behind the sheet metal, there are several ways that provide excellent results - gon2dadawgsExplorergoop it up with any DEPENDABLE goop....and go camping...
- WILDEBILL308Explorer IIBest guess if the JB weld didn't get hard it was old or hadn’t ben stored properly. For quick fixes that you don't need a long work life use the quick set version of JB.
Bill - CruiseomaticExplorerTried different mixing ratios on jb, same results. Cured hard as a rock in the wall but still soft on the outside. Aircraft aluminum is out of budget for now so what I'll do is get some beverage cans and cut to double the size I need for added thickness then rivet them inside the wall so when the screw pulls it pulls from the inside out. Even tried oatey fix it stick and it wouldn't stick to the siding. And I cleaned with acetone. OR, Would I get the same results riveting the new metal outside and running foil tape over the patch to prevent water intrusion? They will be painted over. Riveting on the outside side would be easier but I'm looking for structural integrity and shear strength. Any help would be greatly appreciated.
- the_armadilloExplorerJust an FYI, as opposed to RivNuts the PlusNuts (actually a variant of RivNuts) that I mentioned above are specifically made for thin skinned materials. The pre-bulbed versions can be field installed with a hardened bolt, washer and nut if installation tools are not in hand. Locating PlusNuts are another issue. Our hardware supplier at the time kept us fully supplied along with all of our other hardware.
- camperpaulExplorer
mlts22 wrote:
I wonder if the OP would be well served by Rivnuts. The only issue is that they can end up loosening in the socket, so can spin. I think someone answered that by painting Loctite Red (high strength) around the hole, then using the Rivnut tool to install it.
The biggest problem with Rivnuts® is availability and prices of the required tools.
The second biggest problem is availability of the Rivnuts®.
The third problem is they don't work well in material as thin as the skin on a travel trailer. - mlts22Explorer III wonder if the OP would be well served by Rivnuts. The only issue is that they can end up loosening in the socket, so can spin. I think someone answered that by painting Loctite Red (high strength) around the hole, then using the Rivnut tool to install it.
- the_armadilloExplorerWe used to repair mounting holes two ways on our aluminum skinned doghouses (equipment shacks).
1) For lighter weight items like your marker lights, get some aluminum pop rivets that have aluminum studs smaller diameter than your mounting screws. Secure the pop rivet in the hole. After it is tight, try to knock out the stud head by tapping with a small punch thru the hole in the rivet. If it is too tight, you usually can drill thru the head quite easily with a small drill if you have used aluminum studded rivets. Carefully screw in new sheet metal screws. We often sprayed the screws with a little WD40 before screwing into the rivet.
2) For heavier items, antenna mounts, etc. We would use PlusNuts. - camperpaulExplorerMake an adapter plate out of 1/8" aircraft grade aluminum:
Drill and de-burr a 3/4" hole for the wires.
Drill holes for mounting the marker light; tap these holes for #8-32 machine screws.
Drill a set of four mounting holes in the adapter plate.
Wet sand the adapter plate with 600 grit waterproof paper.
Screw the #8-32 screws halfway into the tapped holes.
Paint the adapter plate to match your trailer. Remove the screws after the paint dries.
Assemble the light to the adapter plate with the machine screws.
Mount the assembly to the trailer with #10 sheet metal screws.
Done. - CruiseomaticExplorerTried JB weld. Kept curing like rubber. Local shop told me to try rivets but something tells me those wouldn't pull the lights in enough to compress the butyl tape. I mixed the jb 1:1 and it would not cure right and come right off the siding. Buddy told me to mix the ratio 2:1. Two parts hardener to one part steel. I was using the jb kwik. I need something to reattach everything to the body without replacing the entire side panels. Some are 29ft long.
Having RV issues? Connect with others who have been in your shoes.24,313 PostsLatest Activity: Sep 07, 2025
