dougrainer
Jul 23, 2016Nomad
motc777 wrote:dougrainer wrote:
From your post, it appears you have a PENGUIN model. Older Penguin's, if the fan motor failed under warranty, Dometic replaced the complete upper unit, as Dometic did not want to pay the 2.5 hours labor to replace the fan motor. They would rather pay the 1.0 hour labor to replace the complete upper unit. Due to the reason's you found out. Doug
Forgot to ask Doug, how can I tell if my motor is still under warranty? Well, if I have already removed it, did I just void that warranty? LOL
11 year old unit? NO WARRANTY. You can use the Brisk Air with your existing control package. Ducted Versus non-ducted makes no difference on the top main unit. It has to do with the inside plenum package. IF you go NEW Penguin, your existing control package will NOT work with it as the NEW Penguins have the control package built in and is for a 12 button wall CCC tstat system. Now, if you have the 5 button LCD wall Wall tstat, then go with the new Penguin and just purchase a new 12 button wall tstat. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
