dougrainer
Jul 23, 2016Nomad
motc777 wrote:
OK guys, the motor works. But I am having a major problem.
I took pictures of how everything was wired up. Except that connector that fits into the control box. I don't know which colors are supposed to go in each hole in terms of the order. Here are the colors I have.
Red, blue, black, green with yellow stripe, white, yellow.
They all fit into a little 6 hole connector plug that then plugs into the control box.
I know that the compressor and the fan both work, but they are not working the right way. HELP! Thanks!
I do not understand what you did. Did you remove all 6 of those wires from the white plastic quick connect? If so, WHY?????? You may be able to remove the box cover and see the other side of that 6 wire connector to align the correct color wires. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
