j-d
Jul 23, 2016Explorer II
If you weren't using a GOOD old-fashioned Analog Multi Meter (like a Simpson, Triplett, etc) with a high spec for "Ohms Per Volt" you won't see that "Kick" where the needle moves on the High Ohms scale as the meter's battery charges the capacitor. Even then, you'll only know that the capacitor is neither open nor shorted. It won't tell you the capacity in microfarads/uF. A cheap Analog won't do the test at all. Same for Digital ones unless they have a uF capability.
If you have a new Dual Capacitor, just wire it up like you first found it and save the one that came in the Kit for another day.
Do you have a Wiring Diagram for this A/C? If so, can you post it?
What is the Model Number of this A/C?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
