motc777
Jul 24, 2016Explorer
Well first of all many thanks to everyone that has chimed in with advice. It has been enlightening and helpful.
I think I have discovered the problem. I verified that my wiring of the capacitors is correct based on the links to the manuals showing how to do it.
So I decided that maybe something in the control box in the ceiling is defective? So I got the part number off of it, and found the service manual. Here is what I found out.
*Thermostat, getting power and checks out on all terminals.
*Next step called for taking the cover off the electrical box. When I did, I smelled something burnt.
*I proceeded with troubleshooting from this manual. http://bryantrv.com/docs2/docs/dt_ac_hp_service_2012.pdf Take a look at page 19-20.
*took out my multimeter and set it for continuity mode. Compressor pin checked out fine, which is the blue wire. But the black pin connector, which is the High/Fan circuit, I got zero continuity.
*Low fan circuit checked out with continuity.
Based on the troubleshooting of this component, if any of those pins is hosed, the whole box has to be replaced. Fantastic.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
