DrewE
Nov 24, 2017Explorer III
Maybe...it depends on the RV wiring, as Harvey51 says.
On my Coachmen class C, the converter is connected to the battery side of the shut-off solenoid, so it will charge the battery with the shut-off switch turned off. It will also not power the camper 12V system obviously.
More common I think is for the converter to also be disconnected from the battery by the shut-off switch. This nearly has to be the case if the converter is built into the electrical center with the 12V fuses etc. as is frequently the case.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
