BFL13
May 27, 2015Explorer II
MEXICOWANDERER wrote:
REQUEST FOR INFORMATION :)
Which portable generator models are suitable for a 9280?
By the way - unrelated - WOOT.com had a WESTINGHOUSE inverter generator 2,200 watts offered last night for four hundred dollars, and high change...
The 9280 is not PF corrected, so it needs a 20a circuit to plug into. (see specs)
It should not run on a Honda 2000w, but Fisherguy says his does. It would run on a Honda 3000 which has a 23.3a (AC) spec. There is a Yamaha 2400 that might just do it where a Honda 2000 should not, but I am not familiar with the Yamaha specs or performances.
I use my PowerMax 100 amper, which is PF corrected, that I twiddled the voltage pot to be 14.8v, and it runs on a 15a circuit no sweat.
I would not touch the PD 80 amper 14.4v job with a barge pole, when I can use my 100a PowerMax 14.8v (as set by me) charger instead with less draw on the generator.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
