landyacht318
Sep 24, 2014Explorer
Mean Well RSP-500-15 Switching Power Supply
IT just arrived.
Initial impressions:
Much heavier than the cheapowatt
1/2" wider, 1/2 inch longer and almost 1/2 inch less High than cheapowatt. The casing is about 50 to 75% thicker aluminum than cheapowatt.
The 40MM fan case is actually flush with the casing exterior, top and bottom, so Max height is 40mm and a smidge.
Voltage range 13.34 to 19.27v. Spec'd as 13.5 to 18v I'd rather have a lower bias, but oh well, perhaps a diode to allow me 13.0 or less.
Little 40MM fan is pretty loud. Cycles on and off even making just 6 amps. More off than on at 6 amps. Runs for about 1 minute on then about 4 minutes off so far. Moves a lot of air when on. Not variable speed.
This fan is too loud for my intended usage, louder than the stock restricted cheapowatt fan. Will modify for bigger quieter fan.
Exhausts air rather than pushing it into casing. I either misunderstood diagrams or they installed it backwards, likely the former.
Voltage Trim pot is marked 102, for 1000 OHMs same as cheapowatt, so I should be able to retask my 10 turn pot. Much smoother to turn and easier to dial in a voltage with provided trim pot than cheapowatt.
When first hooked to 120vAC there is a slight delay, then something clicks, then it starts providing DC voltage.
While the Amber terminal cover on the cheapowatt was hinged on the back, the MW has completely removable clear plastic covers which snap into place, and go flying when pried off from the front.
I'll take pics of the internals later on and post back. I got other projects going on which I stopped to test the new toy, also my 200 watts of Solar has not been able to keep up with my overnight usage, So I wanted to supplement it with another charging source.
The Schumacher sc2500a would have to be tricked into contributing to solar current, with a 30 amp load applied for a while, when battery voltages are above 12.8.
